Awines2326
Silver Member
		Been an MS3 fan since 2013 when I got a Stock Gen2. Drove it for a couple years but had to let it go... Fast forward to 2023 when I decided to get myself a speed3 as a project. I happened to stumble on a great find.
2008 Speed3
Dankai 1 Blueprinted Engine
CS Intake
CS EBC
Full Damond motor mounts
CS HPFP Internals
3 inch catless exhaust
Freektune 21PSI K04
Since purchasing I have added:
CS intake Manifold
CX Racing Dual Core FMIC
CST6
JBR True 3.5 Silicone Intake
Tubular Exhaust Manifold
3 inch catless downpipe - straight dump exhaust
44mm Tial EWG
Freektune 20PSI
I am currently waiting on a CS full Aux Fueling kit to get rowdy with port injection!
It's getting more fun now, and I understand I'm approaching the limits of the Dankai 1 motor. So I tracked down another built motor that was having head gasket / coolant in cylinder issues. I am mid teardown with the intention of building the next motor, with some beefier internals. This will be the first time I've gone inside of the 2.3 MZR so the resources on this forum are gold!
So far I have found the intake cam is trashed, caps were very loose and there are deep groves on every intake cam cap. Crank is scored, the OEM main bolts were also loose and the clutch side main bearings was dug deep while the rod bearings looked perfect. Pulling out Manley rods & Manley 88mm Platinum Pistons that don't look to have very many miles at all. Pictures attached of what I've found so far, and incredibly open to hearing advice and suggestions from those more experienced than myself on this journey!
			2008 Speed3
CS Intake
CS EBC
CS HPFP Internals
Freektune 21PSI K04
CS intake Manifold
CST6
44mm Tial EWG
Freektune 20PSI
