Mazda3speedster
		Hey, fellow speedsters
I just got this car and it came with this code, Ive never owned a Mazda but I didn't think it would be a big deal, so I was looking into it and I found many possible solutions and Im not sure which one I should follow, It has a 91 octane stage 2 tune not sure what it is specifically(OTS tune from cobb i believe) I put a picture up, popped the hood today and there seemed to be a ticking from the right side of the intercooler(seemed like the hpfp), the ticking got much quicker when I got my buddy to rev it to about 1k rpm, the previous owner also got the heads redone so I don't believe its valves, or the timing chain. I also seen that I should replace the purge valve, and check for any vacuum leaks, I was also told to check the STFT which ran between -25/25% which is not normal, wondering if its the hpfp or if any of you guys know what my issue is. also got some unnormal knock retard
Thanks for any help in advance,
