08Speed3
Year/Make/Model: 2008 MS3
Mileage:240000km body / 150000km engine
Concern: Car stalling at idle / wont go into boost
DTC's: secondary o2 heater
Modifications: Turboback exhaust Catless DP, Autotech HPFP, 70mm intake, ebay TIP, HKS SSQV
ECU/Tuning Software: Accessport. Does have a China Turbo on it right now, only 10000kms old and still builds boost fine.
Tuner: Justin
Is the concern intermittent? no
Can you duplicate the concern? yes
Recent Repairs: New Denso MAF, New MAF Pigtail, New Bosch OEM MAP sensor, New set of coils, New NGK plugs at .028, New air filter, New battery, Injectors cleaned and flow tested
Correction:
This car...
It was fixed for awhile, running fine after I replaced the MAF a month or so ago. Was running 100% no issues until last week. On my way home car died going around a corner, maybe 15mph engine just shut off completely and coasted to a stop. took key out and it restarted right away.
after that happened, car didnt want to go into boost, ran fine in vaccum but as soon as you load it up a bit and it starts to build boost car violently shakes until you let off, I got it back home and pulled the plugs to check, looked fine, gap was still good. put everything back together and swapped the coils with another set I had. Car actually ran great all day thursday, built target boost of 22lbs, didnt hiccup once. Let car sit all weekend and got in it this morning and started it up to warm it up a bit. Car idles for 30 seconds then dies on the driveway. Started it back up and took it down the street, went maybe 2 kms down the road and it felt a bit off, very slight hiccups like a small misfire and when i went to merge onto a busier street car started to accelerate, build a bit of boost, then shook violently like before and when I let off it died. Coasted to a side street and sat for a minute. Car fired back up drove fine in vaccum, so I started datalogging and recorded it happening. Leaned into the throttle a bit and it did it again, bucked hard until I let off, but stayed running this time. Went right home and parked it and took my beater truck to work.
Ideas Floating around my head are maybe CKP sensor dieing, maybe bad grounds, Cam sensor maybe? Any tips on diagnosing? I've thrown so many parts/ sensors at this car to fix it lately its really discouraging. It does have a shitty newer china turbo on it, but it doesnt burn oil and it seems to build boost just fine, but I guess I cant rule out that either. That wouldn't explain the dieing at idle though.
Thanks for reading....
Tuner: Justin
Correction:
This car...
