2009 Speed3 Codes P2177, P2187, P2195
Brian R
Hey everyone I am getting three codes on my AP but the car is running fine no missfires or running rough I've cleared the codes and they come back again. Any ideas where I should start? I have small mods like Cobb intake, HKS BOV, HPFP internals and COBB off shelf tune. Thank you.
Have you checked out the shop manual? It has all the diagnostic procedures in it for the error codes
https://mazdaspeeds.org/index.php?forums/mazdapeed-owners-manuals.193/
Clean that MAF sensor and ensure it's plugged in and facing the right way, check for leaks from intake to engine.
What is your fuel pressure reading? Worth having a look into the PRV here's a good video.
Also could be as simple as a bad primary O2 sensor if you do replace it only get NTK (OEM)
