myosin
		Story time:
Car has been daily driven and has been absolutely great to me. Recently got stuck in a snowstorm - pulled into a parking spot that had a bit too much snow and car got high centered. Parked the car for the day to go to work and then came back, car struggled a bit to start, but then made it home.
Fast forward to the next day - car would start for a couple of seconds and then immediately stall out. Holding the gas or clutch in did nothing. Smelled some burnt/unburnt fuel, don't remember exactly.
Left it for a week; battery was dead so I went out and purchased a new battery. Cleaned the MAF sensor at the same time just to be safe. Car cranks but does not start at all, whereas previously it would start and stall out after a second or two.
Next on the list is to replace the spark plugs(hopefully some time this week) - just wondering if anyone had any ideas as to what other problems this could be caused by.
Possibilities:
1) Fouled spark plugs
2) Could the OCC and lines be frozen, thus preventing the car from starting up?
3) Injectors - will probably get them flow tested and get injector seals.
Note that I was running an E30 mix in the summer but then switched back to 91 for the winter. Car was on 91 for probably a month or so before this incident happened.
Mods:
NGK One Step Colder Plugs
CST4
Catted DP
CAI
TMIC
Dual catch cans/DM PCV Plate
Freektune
Possibilities:
Mods:
CST4
Catted DP
CAI
TMIC
Freektune
