Jerome
I’ve been having an issue with the car burning a lot of oil. Blue smoke or grey smoke clouds when I hit the gas after being stationary for as little as 30 seconds.
I have done a compression test (180psi all 4), leak down test (20% all 4), new to me used k04 turbo 80k miles didn’t smoke when pulled, new PCV, new oil, coolant flushed.
I guess my question here is, where do I go after this? Maybe the oil rings and holes are stuck/clogged?
167k miles gen 1. PO states the head is also new. Timing chain at TDC is good.
