ryanz1243
		I have a stock diameter Corksport ram air intake and BNR S1. It is on the stock Cobb map (should be same as Mazda OEM afaik). Everything else is bone stock. I only run 93-octane fuel.
I'm getting P2188 (Rich at idle) and can verify it idles rich, at least if the AC is off... either way, LTFT is a bit high and/or all over the place, but always positive.
My current plan is to replace the spark plugs which are getting pretty old according to those who change them religiously. Other than this step, I'm all ears for suggestions on how to fix this. A lot of other threads end in people seemingly replacing half their intake and then giving up.
Also, attached are several logs with descriptive titles. All were taken today with 85 F temps outside. Hopefully something in there is helpful.
