Convert MS6 Bilstein B6/B8 to Coilovers
  • Thread starter Thread starter phate
  • Watchers Watchers 1
phate
Motorhead
I've been running this setup for the better part of 10 years. I'm using Bilstein B6 as the base for my coilover setup and have had them re-valved by FatCat Motorsports. The conversion is super easy - and allows you to run a standard 2.5" ID spring in the front so you can get any spring rate imaginable. The rear springs have some options from QA1 that will serve most people pretty well.
Note: for the B6 vs B8 debate - in this case if you're getting them re-valved for a coilover setup, get the B6's. The longer rods in the B6 offer more droop travel and that's a GOOD thing. There is absolutely no reason to get the B8's.
Front:
Bilstein B6 / B8 Right: 24-102575 / 24-102605
Bilstein B6 / B8 Left: 24-102568 / 24-102599
Threaded Sleeve: A-1 12456
Adjuster Nut: A-1 12460
Nut Set Screw: A-1 12485
Top Hat: BC Racing - Call them for ordering just the top hats. [I made my own out of steel plate and a polyurethane bushing, so I don't have this part #.]
Springs: literally any 2.5" ID spring from your favorite manufacturer - Eibach, Hyperco, etc.
Rear:
Bilstein B6 / B8: 24-102582 / 24-102612
Spring Adjuster: BC Racing - Call them for ordering just the rear adjusters.
Springs: QA1 Mustang II Springs offered in 375/500/600/700 lb/in options.
