Matt@DamondMotorsports
https://damondmotorsports.com/produ...255&utm_medium=email&utm_source=shopify_email
The Damond Motorsports Electronic Boost Control Solenoid kit (EBCS for short) is the perfect solution for managing boost on your turbo setup. Every turbo application can benefit from running a 3 port. Benefits include faster turbo response, and potentially higher boost at high load.
We utilize a genuine 3-port MAC valve straight from the source, so you don't have to worry about a knock-off valve. It comes pre-wired to a factory style Mazdaspeed connector, allowing for a no-wiring-needed install with a quality valve that won't let you down.
The 3-port EBCS can be used with internal or external wastegates, and can even be setup like the OEM EBCS in 2-port operation. We include 2 straight fittings and 2 90° fittings, to allow you more flexibility with mounting and hose routing. We also include a bracket that features multiple mounting holes, and fits in multiple directions to allow you to mount the EBCS as you see fit.
Included:
Note: This product is intended for off-road use only.
Included:
- 1 x 3-port MAC valve with OEM Mazda style connector
- 1 x stainless steel mounting bracket
- 2 x 3/16" straight barb fittings
- 2 x 3/16" 90° barb fittings
- 2 x vacuum caps
- 3ft of 4mm silicone vacuum line
- 6 x zip ties
- mounting bolts and nuts
