Im upgrading from my home brew OCC to a DM unit and have been questioning location choice.
I had originally located my OCC in the engine bay off the clutch tube bracket. In that area, I would drain mostly residual condensation with some oil and usually smelling heavily of gasoline. I then moved my catch can to the horn bracket where I feel the temps around the can could be lower. I found that the amount of condensation in the can was less, but the amount of oil was slightly increased. However the overall amount of liquid in the can was reduced.
Location 1 is mounted on the horn bracket. Possibly a slightly cooler environment leading to more condensation of the oil laden gasses from the PCV.
Location 2 is mounted on the clutch tube bracket. Leading to easier hose routing.
Am I overthinking this, is there merit to the idea of OCC placement?
