Speedie6
Silver Member
So, I've got a lot of CorkSport parts. Including the adjustable rear camber arms. Only have about 12,000 miles on them. Left one failed. I didn't even hit a pothole or anything. I was on the freeway. At first, I noticed it felt "funny". Then I heard something that sounded like rubbing in the rear. So, I figured I should slow down and exit the freeway. The exit was a bit away, I didn't really know how serious it was. But I figured it would make it to the exit. As I was going down the exit ramp, the rear tire blew-out. I exited and there was a business parking lot right by the exit that I parked in.
I had it towed to a general auto shop. It was installed by Kozmic Motorsports in Houston, so I would think it was installed correctly. But it usually takes days to weeks to get an appointment there. So, I figured a general auto shop could probably diagnose it and had it towed to one. The shop said that the broken camber arm caused the rear trailing arm to bend, so I need that replaced as well. The mud guard is scraped up, but probably can leave it. He said the axle and CV joint seem fine.
Now, I don't know if I should even go back with another CS camber arm or not. And whatever I do, I probably should replace both sides. If one broke, not sure I trust the other one. And I need new tire and the rear trailing arm.
So, here is the picture:
