AndrewC08MS3
Thanks in advance for your input and time!
Needing to be addressed, 1: fuel leak. And 2: Minor oil leak
Ok guys, I’ve owned my 08 Speed3 for 5 years now and it’s my pride and joy. This past summer, (8/2021 and 2 years in the making) I installed a SP63 stage 2 long block (at work thankfully) to avoid having a zzb fiasco down the road. 150k+ on original engine and clutch.
Fast foward to December 2021 I started smelling gas on cold startups coming through the vents if not on circulate, and under the hood. This would only happen if outside temperatures were below 60°(I live in Wisconsin) and, It would go away once the engine reached operating temperature. Nothing reaching the ground though (yet). I grabbed a fellow mechanic I work with for a second set of eyes and all we could find was the area of the block beneath the HPFP was wet from there down (more on this in a bit). It’s not the feed or return to/from the pump so I got the hard line on order right away that goes from the pump to the rail.
Then, once the ambient temps got below 20F, now we’ve got steady fuel leaking onto the ground and it appears to be coming from CYL #1 or #2’s injector where it seals into the fuel rail. It’s difficult to see much without tearing it apart and removing the manifold but it’s my DD so i’m trying to cover all of my bases and hopefully have everything I need before digging into it again.
So, the area right under the hpfp thats wet…. It’s definitely oil. There’s a BIG internal Allen plug (probably an inch or so) on the drivers side going into the block and it seems like that’s where the oil is very slowly seeping from. Or, it’s one of the HPFP gaskets but I replaced all of those so I don’t think it’s likely but who knows.
Thanks again for any help.
Relevant mods:
BNRS3, JBR 3.5”, JBR mounts, 3.5bar MAP, Autotechs, snow stage 2+, Cobb Turboback, Apv3, e30 tuned, stock manifolds and no port injection yet until then
Relevant mods:
