Rgurleyjr
So in my quest to try and figure out why my car isn't taking gas at the pump, I decided to start with the so called evap filter.
First step is just to Jack up the passenger side rear. As seen in the picture, it is supposed to be attached to the filler neck and mine was zip tied.
Once you remove it from the filler neck, pull the entire assembly out the bottom where you can remove the cap. As seen in the picture, all you need is a flathead screwdriver. The cap simply locks onto the body and just work it from one side all around.
Once cap is off, there's the filter. Mine was so old, it crumbled and fell apart. For now, I removed it and reinstalled the assembly. After trying to fill up, same problem. Grrr.
Anyways, pretty simple procedure. Worth checking out if you have evap problems.
