How-To Replace Shaft Pivot Seal
Vansquish
Silver Member
This thread was originally created by @jrzy ms6 on MSF back in June of 2012.
ok so i noticed trans fluid leaking and traced it to the rubber boot on the pressure plate on top of the trans. found some helpful threads to help pinpoint it but no "how to's" so hope this helps cause the dealer charges BUKU dollars to fix (yea what else is new). i'll start by saying that i consider myself a noob under the hood but i can figure stuff out. so feel free to chime in cause i cant name all the parts involved or dont know if there is a easier way to do it. all i can tell u is that this is what i did, everything works and best of all no more leaky leaks.
the seal from the dealer was only $6.50
part # A60117131
1. remove the air box for the intake (i'm all stock) and the battery, battery tray.
under this rubber boot is the seal. will be fluid all over this area
2. disconnect the clutch cables. i used needle nose pliers to pop off the top one the other is connected to a bracket on the plate that has to come off anyway so i just pulled out the two 12mm bolts holding it
3. remove the motor mount. before you do this you must set the front on jack stands and support the engine from under with a floor jack to release tension on the motor mount bolt.
(i'm on h&r's so i had to jack it from the side and slide a old rim with a box on top under the trans to support it.... had no jack stands).
at that point remove the bolt going thru the chassis(on top in pic) 18 mm i think and be sure not to lose the nut on the back side of the mount. then the other bolt going into the trans
2nd bolt going into trans, its under the clutch cables
3rd bolt going into trans, and the nut from the chassis bolt that u already dropped into the engine bay. mount should come right off now
4.pull the rest of the 12mm bolts out of the plate and break the seal holding it to the trans (i used a big flat head screw driver)
5. ok i'm not 100% sure this bolt had to come out but the shaft was fighting me to come out and seemed to come alot easier when i did. its located on the front of the trans and is lined up perfectly with the shaft. once it was out i was able to wiggle the shaft out (no homo)
shaft out
6. remove cotter pin, a punch is perfect if you have one. i dont so i used a
t25 torx driver and a hammer to tap it out.
7. once the pin is out slide it off. i think it only goes back on one way but be sur to keep an eye on how it came apart
once thats off the plate slides right off, the seal is right on top.
put on the new one and get her back together
Edit: some have popped off the shifter cable and had a small clip left on the plate. be careful not to lose it and set it aside for reassemble.
Also clean off the old sealant from the plate and trans and reseal with gasket sealant.
