Lazza151
Sooo, the day has finally come to part ways with the stock KO4 turbo.
Went for a spirited drive Saturday 22 April 2023 and all went well.
Come Sunday and my turbo starts to make a grinding noise when the boost comes on along with smoke out the exhaust at idle.
I can now smell the oil burning.
Knew this day would come as I had installed a banjo bolt and raised the idle at about 80 000 km all the while running a tune with about 20 pounds boost.
Now at 160 000 km / 100 000 miles the turbo is done.
Even knowing this day would come I wasn't prepared ( Funds wise)
Nevertheless I started to make some plans and to take some action to rectify the situation.
After about a week of driving on low throttle to avoid going into boost I decided to park the car .
25 April 2023 Ordered the Following:
1 New Original Coolant Reservoir - Old one was starting to leak slowly - coming from Japan 6-8 Weeks
2 New Original Bearingfront Struts and Bumperbounds - coming from Japan 6-8 Weeks
2 New Monroe Front Shocks - Original Mazda shocks were just too expensive
2 New Monroe Rear Shocks - Original Mazda shocks were just too expensive
1 Cobb 3 Port Boost Controller - Arrived today via UPS
1 Bosch 3 Bar Map Sensor from JBR - Accidently picked USPS instead of UPS so this item may take weeks or even months to get here - May have to order it again using UPS as time may be an issue.
Still to Order / Fabricate:
1 Pulsar PTX2871R Turbo (Sadly changed to PTX 2860 Gen 2) hopefully lasts ok.
1 Custom fabricated 3 inch intake with nice big K&N Filter
Custom tune from one of the known e-tuners
This whole saga introduced me to a local track car builder who will be doing all the wrenching as I am a bit ham fisted and some custom fabrication will be needed ie,3 inch Intake ,Turbo Inlet from exhaust manifold and Turbo to downpipe Outlet.
Wish me luck..nerves are shot .
