Stefan01234
Hey guys, so I've been trying to play with my VVT table on my Gen 2 Mazdaspeed 3 to spool my turbo faster, but I've not been having any luck with it, hoping someone can help:
Referring to the above comparison graphs, both logs ran at around the same date/time/conditions. With the difference being 10 degrees of VVT (15 vs 25). Basically, no change in spool time across the entire RPM range (3k-5k) hitting peak boost at 4.5k rpm (21psi). I've also tested VVT at 30 degrees and the results are basically the same too, no difference in spool time, in fact I felt that at VVT 30 degrees the car actually felt slower during spool time. WGDC is also set at 100% up until 4000 rpm, then 40% at 4500rpm.
Is there something wrong with my MS3 or is the above to be expected of my setup?
Mods to name a few:
CS Intake Manifold
CS Exhaust Manifold
CST5 Turbo (Journal Bearing + IWG)
Stock Camshafts
Mods to name a few:
CS Intake Manifold
CS Exhaust Manifold
Stock Camshafts
