stockms3
		I have researched different clutches, read different threads. However, my main concern is pedal feel. I need it to be as close to stock as possible. Before you call me a pussy I have a connective tissue disorder and my tendons often hurt (it is quite shitty).
My car is built, running CS turbo @ 23psi and LUK/Fidanza combo is slipping.
Anyway, what I have learned so far:
ACT 6 puck - most popular option, apparently ACT recently reduced the required force to press the clutch pedal but still harder than stock.
SPEC stage 3+ - a guy that reviewed the clutch on Edge is claiming that it is lighter than stock and it would be sufficient even if I add meth to my setup. This is why I am leaning towards this clutch. However, I did read bad things about it on several forums.
Southbend - i have read different threads about different stages but all I heard was that it is quite heavier than the stock clutch.
Anyone want to chime in and talk about their setup? Maybe someone with a SPEC clutch?
