Need help with “module configuration error” RCM code
mrsweetness09
Hey guys, currently dealing with a “module configuration error” RCM code after attempting a gen2 to gen1 seat swap. I messed around with forscan not knowing what I was doing to try and clear it a while back (like a moron) and managed to disable the passenger weight detection in the non As-Built module configuration section for the RCM and now I can’t get it to go back. I ended up using the “load factory AsBuilt data” feature in forscan but suspect it to be incorrect. Can someone with a 2012-2013 speed3 and an extended forscan license go into the AsBuilt configuration menu of their RCM and send me a picture or a screenshot of the data as it stands in your car?
Adding image of what the screen im looking for should look like.
PLEASE do not mess with or change any of this data unless you want to end up like me, just stop the procedure and don’t mess with any of the values.
