New Speed6 Owner Intro!
  • Thread starter Thread starter swaggyT
  • Watchers Watchers 3
swaggyT
Hey ya'll! Just got an '06 speed6 and thought I'd make an intro here. Got the car in August, 175000km / 110000 mi, $6300CAD / $4500USD with no info regarding VVT/timing chain, and a clunky front suspension (and as I found out, a transmission fluid leak). Decent body for its age - Alberta driven most of its life but in Ontario now. I was definitely paranoid about the VVT and after about a week I definitely heard the rattle so I ended up taking it to my local dealership, now it's fixed and I've been dailying it for about 3 weeks. Dealer tech had a good look in the engine bay and found/fixed a few other bits but said everything he saw looked to be in pretty good shape. I thought the transmission leak could be either backup light switch or neutral sensor but now I am second guessing it. Going to check it again this weekend to see what I find.
All that aside, car is bone stock, and I got good vibes from the previous owner. Doesn't seem beat up aside from being driven with low tranny fluid, and the turbo has some slop. A bit of rust on the driver's side quarter panel that I got a quote for $1200 to fix. Also considering dry-ice blasting the undercarriage to hit the surface rust. Just found a part-out that has pretty clean strut tower plates so I'll be swapping mine out soon.
I love this car, and will probably do anything to keep it on the road - parking it for the winter, may be outdoors but at least it's not picking up salt. Will probably start a build diary sometime. Definitely open to ideas for the path to take this car; at the moment I'm considering HFPF + accessport map + rear motor mount as a starting point. Then, when the turbo dies I am toying with the idea of CST4 turbo / intake / exhuast / TMIC. I did some auto classes in high school, and I would consider myself novice but able to figure things out, and will use this as an opportunity to develop my skills.
Cheers!
Welcome! Not too bad of rust for 19 years. Definitely treat if to prevent or reduce further rot
