Speed777
Just wanted to know from those who have build your engine, what is a normal oil comsumption considering
an engine that has mahle 4032 pistons with manley h-beam rods?
i topped up my oil yesterday, used the car locally with a couple of wot
and this morning when checking oil level i had to pour a little bit to topped it up. Is this normal? because i was told that build engines consume more oil, is this a fact?
All of this checking of oil comes because unfortunately i had a check engine light stating it was lean and i even didn’t realize for a moment the seriousness of the light. I erased the code and kept running the car but contacted Justin to get map adjusted since we are on the middle of correcting a previous rich code i got
which in return he sent me a revision to which i got this lean code.
All im worried is that rings might of gotten damage. its really hitting my head
