Oil leaks from head gasket
JustJoseph_
I spun a bearing last year and I was able to get the pistons in and everything back together when I went to start it the first time it’s started right up but when I stopped the engine it leaked a shit Ton of oil out of the head gasket so I bought new bolts took it all apart re did the bolts and it still seems to leak oil out of the head gasket I replaced the oem head gasket with a cometic head gasket torqued the bolts down 60ft lbs + every thing seems to be right but is not working any ideas ( I know I’m going to have to tear it apart again but before I do I need some advice)
The head gasket can be put on backwards and allow it to spew oil from the center galley on the front of the engine (under the intake).
