p0192 fuel pressure sensor purchase
1secrets
Year/Make/Model: 2007 Mazdaspeed 6
Mileage: 202000
Concern: Wont start or hold
DTC's: (please include descriptions) p0192
Modifications: FMIC,INTAKE, DP, 3" exhaust
ECU/Tuning Software: AP v3
Tuner: none
Is the concern intermittent? yes
Can you duplicate the concern? yes
Recent Repairs: none
Correction:
Alright hopefully this is the right way of posting it, But issue Im having is the p0192 , Kept erasing the code and didnt think of it.
On thanksgiving day gave it gas and then boom car went into limp mode got it into parking lot.. would idle rough for 10-20 seconds then shut off.... Ordered the sensor(which wasnt bosch but was proper part number) starts up but want to hold.. HFPF drops after 15 seconds.. then shuts off
So my question is, I know what the correct part number is (thank to dinner and chimii post from looking)
Where am I able to get the actual part ...local wise or fast quick turn around time
if this isnt right way lmk. Thank you.
What does the accessport actually read for your fuel pressure? Sometimes you can get a 192 for having a bad fuel pressure relief. A datalog of you trying to start the car would be beneficial here.
Here’s a way you can test it. Disconnect your spill valve electrical connection and turn the vehicle over. If it runs, you’ll see something like only 40psi of fuel pressure (maybe up to like 80 on cold start, but suffice to say it’ll be concerningly low).
If by disconnecting the spill valve your car runs fine, it’s the relief valve. As an aside, you can drive the car without the spill valve connected, do that at your own peril, but do NOT go into heavy boost or high throttle or rpm.
I do have a proper sensor coming should be here this week.. one of the guys on facebook group had it and sending to me. I will try this in the morning and report back. or should i wait til part get here first?
Your discretion, but I’d say test it at your earliest convenience. Fuel relief problems commonly get confused with fuel sensor.
heard will test in morning. even with the code popping towards that sensor but im guessing that code could be like 3-5 things correct releated? but here's the question should I put back the original sensor back in when I test it or one i picked up in 074?
For the purposes of the test it won’t matter too much. Without a spill valve, the car won’t run at a pressure high enough that whatever sensor is there will have any issue reading.
heard andd one other favor... can you tell me what im disconnecting.. like a show and tell lol cause i think I know what to unplug but just want to make sure (guess on top of the hfpf?)
This connection here (not my image, I just donated the circle).
So got around to it...try to start..(been working) start and just die....nothing moved on the hpfp on Cobb at all
Right now only code is p0091 fuel pressure regulator 1 control circuit low
Yeah, that's a spill valve code (which presumably you disconnected). It should definitely still run though, even without the spill valve. Case in point, see attachment.
If I still lived in SoCal I'd just drive to you to help you out lol, used to live in Oceanside. This is pointing me more towards it being you FPR, and I'm almost positive of it at this point given everything you've said and we've spoken about. I suppose I should still say take that as my best guess, not me telling you it definitely is, I just *think* it is. You can try to wait for more people to weigh in though. FPRs sure ain't cheap.
well i get the sensor monday..i do have a hfpf back up (stock internals) but yeah might be the spill vavle
yeah if you were here be great cause i could be back on the road= [
Well the part you'd replace is actually the relief valve on the side of the fuel rail, not the spill valve itself or HPFP.
https://edgeautosport.com/mazda-oem...7-2013-mazdaspeed-6-2006-2007-cx-7-2007-2012/
Those guys. You can pull one off of a CX-7, speed3 or speed6 from a pick n pull as well.
