SnakNP215
08 mazdaspeed 3 So yesterday I got to work and noticed that the display screen that shows hvac information was blank, popped fuse box cover by passenger side footwell n check radio and illumination fuses but all where good, go under hood to check fuses there n all good, go to put the ignition switch on and the screen is back on, crank the car and check engine light is on, not throttle response, hook up scanner and get p2101 code for throttle body, erased codes and reset battery and nothing, can the throttle body just happen to go bad out of nowhere or did I mess something up while I checked fused for the display situation? Double checked everything I touched and everything looks good, can anyone point me in the right direction please…forgot to mention that it also has a misfire now too like a bad spark plug, coil work but cylinder is not firing, also happened wen I went to start it after checking fuses
