[SOLVED] Randomly loses fuel pressure
Brockm
Year/Make/Model: 2008 speed 3
Mileage: unknown rebuilt by previous owner
@Roger Mesler
Concern: loses fuel pressure when throttle is inputed, doesn't make correct fuel pressure at idle
Modifications: hpfp upgraded Internals, bnrs3 turbo, 2 aem fuel pumps and inline filters, it has a fuel cell because it has been converted to awd, front mount intercooler, Manley H beam rods and weisco pistons
ECU/Tuning Software: Cobb Acessport
Tuner: Freek Tune 93 bnrs3 (base tune)
Recent Repairs: tried cleaning the hpfp Internals and the sensor on top
Did you use an oem sensor and replace the entire rail? Is the one on there now working correctly?
You could have idled for as long as needed on the old one.
It was hard to get it to start on the old one replaced the prv and the new one doesn't seem to want to start but it will randomly go up to 500, 700 and 1000 psi on different start up attempts most of the time it is in the mid 60's
I took the pump apart, the retainer clip that goes above the spring and holds the keepers, Is there a website where I can get a new one
Mine got lost in the disassembly process
