kckid816
Year/Make/Model: 2013 Speed 3
Mileage: 128k
Concern: slight rough idle, safe mode while driving
DTC's: (please include descriptions)
Modifications Corksport TIP
ECU/Tuning Software: Stock
Been tracking down the misfire and lean codes for this has been a nightmare.
I have replaced both O2 sensors (they were reading low voltage), fuel injector seals, new OEM mass airflow sensor, rebuilt HPFP with a Corksport kit, new gas cap, replaced the pressure relief valve, new pcv, cleaned the intake valves and have replaced the fuel rail pressure sensor.
Originally it was misfiring with P0300 and P0303. Now it is throwing P0171 and P0300 but they won't stay on.
It keeps putting short term fuel trim at 25% but it reacts normally when on throttle.
My fuel rail pressures are reading slightly low at idle and key on, engine off (20-40 kpa).
When the car doesn't go into safe mode, throttle response and power are good. Seems to go into safe mode more while driving it vs giving it throttle sitting in the driveway.
Pretty much certain there is not a vacuum leak despite the lean code but have not done a smoke test.
So what could it be?
I'm leaning towards the tank fuel pump filter being dirty but I really don't want to drop the tank to replace it if I don't have to because I'm trying to sell the car without doing anything more if possible.
Mileage: 128k
