Stuck crank pulley
Ssinstaller
Like the title says, trying to re-time my motor and got the crank bolt out with no issues, but the pulley is stuck on there..really stuck!
The pulley will rotate, but it will not come off the snout. I don't want pry against the timing cover, but I can't get my puller in there to grab anything.
Before I go and buy/rent a different one... Has anyone else run in to this issue? If so, what kind of puller did you use to get the pulley off, and where did you get it..
