StevieWonder711
Mileage: 161,000
Concern: Car idles rough, TB doesn't open
DTC's: In the pic
Modifications: bone stock
ECU/Tuning Software: Versatuner
Tuner: Stock tune
Recent Repairs: Cleaned Maf sensor, valve cover gasket, oil change, trans fluid change, new front axle
Correction:
Some back story: I bought this car on marketplace and it drove good back to my place over an hour away. Used versatuner to see how exactly engine was running and had erratic AFRs (29+ or 8) but it seemed to drive and idle ok. STFT were always at +25%. I cleaned the maf to see if that helped the AFRs and car idled worse. I couldn't rev above 2k rpms and got all the DTC codes (attached in pic).
The flapper of the throttle body wouldn't move when I had the battery on, do these codes suggest I just need a new throttle body or are the computer components fucked up?
			Mileage: 161,000
DTC's: In the pic
Tuner: Stock tune
Correction:
