Background:  About 4 months ago I decided to inspect some of my fluids.  I went and removed the fill plug on the trans and noticed a faint whistle coming out as I slowly removed the plug.  I thought it was a little strange, it turns out the fluid was a little low also.  I went ahead and topped it off with another half a quart of gear oil (I had half a quart of Amsoil Severe Gear oil from last time I changed it).  Topped it off and drove it until now.
Today: I was changing some fluids out, hooray! The time came to swap out the Trans gear oil, and when I opened the fill hole the transmission started whistling again! It seems as though it had a build up of pressure inside that couldn't vent despite the breather vent by the pivot shaft.
I check the axle seals and and all the bolts, and everything is still tight with no leaks. I had some spare hose, so I plugged the drain plug back up and shoved the hose inside the fill hole. I placed my soft supple mazda loving lips on the hose and gave it a good blow. All the pressure came back out through the hose. I did it again and blew harder (a little more tongue and neck this time), same thing. Now I'm thinking, "maybe I'm blowing too hard and overpowering the crack pressure of the breather vent." So I gave it a third light blow of air and put my fingers surrounding the vent (think rusty trombone), nothing came out.
I'm a little concerned that the pressure might lead to axle seal leaks, or even worse a leak into the bellhousing. Im considering removing the pivot shaft and replacing the vent or modifying it somehow, and also replacing the pivot shaft seal and bearing for good measure.
Has anyone ever had/heard of this? Or maybe if anyone knows the crack pressure to that piece if crap breather? My GenPu only has 50k miles on it, which is the real head scratcher...
Thanks for the gayz...
(Mod's feel free to move, I may have posted this in the wrong area.)
