72mm Throttle Body...and it works
Do you want this; Do you need this!?
  • Total voters
    48
All is good in the hood. Driveability was awesome. I am in the midst of getting retuned to see if i was able to pick up more power from installing the bigger TB. The only unforseen part was needing longer bolts (mine didnt come with any...)when useing that adapter plate luckely i had my hex head bolts laying around from my TB meth spacer that did the trick. The plate was nice and simple for the st mani. Now i am gasket less on my tb setup.
The only problem Im experiencing is harsh jerking when I let my foot off my throttle. Something @Sho told me relates to the DFCO table that is not available for adjustments via Cobb ATR.
Stop and go traffic was annoying since you're between 0-5% throttle so much where you really don't have much resolution with it. Once you're moving though I found it to be very nice to drive with.
I probably would've had zero complaints with the touchy throttle if I didn't use the car to commute from time to time living smack between Baltimore and DC.
Edit - this was also with a 6-puck which probably added to the touchiness of the throttle/clutch relationship.
Damn, that sounds like its gonna be annoying as hell, i just got one from a partout so im waiting for it to come in.
IS there a fix for this or a reason for whats causing it?
AFAIK, DFCO is decel fuel cut off (someone correct me if I'm wrong) and not being able to adjust it w/ the bigger throttle plate causes the issues that some are having. I know people that daily it and get used to it, but if you're picky about drivability and comfort, it may get to you. I guess it depends on the person driving.
Exactly. If you don’t care because race car, go for it. I personally do not like it( because I’m boujee and a snob) and will be switching to OEM when I have the chance.
I didnt like it at first.. but after 1000 miles of driving you just take it as it is. Really isn't bad to drive with. But if you have a set power number you want this will help you get there.
Hmmm alright fellas, i appreciate it. I got one from a partout, should be here any day now. I'll ride around on it for a day or so and see how i like it, if its annoying ill go back to OEM and sell it. Sucks Cobb wont update the Accessport to accommodate fuel cut... ah Well.
I appreciate the advice and speedy responses! Im actually going to start a thread on my custom modded Tech package lights if you guys wanna check it out!
i've got the TB on my car now, i did multiple pulls and would let off and felt no jerking whatsoever.
