jdab555
[Resolution Edit] - It was the Thermostat. Don't trust your thermostats.
Hello,
I've been running into an issue where my car (2007) will somehow get air into the coolant system very 5 or 6 times I drive. My car sits a few days a week since I don't drive it often, but there doesn't seem to be a correlation between when the air will get in and how often it is started up. It's a bit odd in that it doesn't overheat when driving hard, on long interstate drives, or around town. It will just decide that today is the day it wants to let some air into the system.
I'll notice on the AP that the coolant temp will climb a bit faster than normal, and begin to climb steadily past 190 up into the 220s+. When I see that, I let it get up to temp, park it off for about 3-5 minutes, gently crack the coolant cap to relieve a little pressure while it is still hot, and then seal it up and start the car up. At this point I can see a lot of air has gotten into the system as it bubbles into the reservoir and the level drops back down to normal. Temps are then fine and I have no further problems for the rest of the day. This is a guaranteed routine for me to fix the issue every time.
Car drives fine and runs perfectly, no discoloration of the coolant or oil contamination, and no sweet exhaust vapors or smoke, so I am doubtful it could be the head gasket. I have replaced the thermostat to no effect.
Possible causes: cracked hose, faulty coolant temp sensor / sensor seal allowing in air? I am inclined to believe it may be related to the sensor as the pressure relief + a start up bring the temperatures down sharply from the 200s down to 190 almost immediately, meaning air is sitting trapped in that section(?).
Curious on thoughts before I chase down a new hose kit or sensor.
Hello,
