Put in a lot of work this weekend and was able to get the engine in!
First I finished up some odds and ends with fuel fittings, coolant hardline delete, etc. then got to work on the clutch & trans:
Then today was able to get the wiring harness back on (I’ll get around to removing the EGR & VTCS plugs once things have settled)
Took me about 4 hours and a lot of cursing to get the engine bolted to the mounts but she’s finally in!
Obviously still gotta hook a lot of stuff up and route all the vacuum/boost hoses but definitely making progress!
Also forgot to put the serpentine belt on before dropping the engine back in, and surprise surprise when I go to put it on in the car the bolt on the tensioner strips . Any recommendations on replacements? OEM only or is the auto zone special acceptable?
Then what do y’all recommend for break in oil? I’m tracking conventional & high zinc but I just wanted to see if y’all have any specific brands/etc. that you guys like?
