Desired AFR not matching whats in tables (Versatune)
Mr Charge
Hello partners.
When I look at the logs on Datazap.me, the desired AFR does not match what is listed in the "Extended Closed Loop AFR Target", "Extended Normal Open Loop Partial Throttle AFR Target", and "AFR Target" tables. extended normal WOT open loop".
The 3 tables have the same values. The "Open Loop WOT AFR Target Normal Extended" takes the richest values of each rpm range from the tables above.
In the records, the "Desired AFR" appears richer than the tables indicate,
¿What is happening?
Greetings and thank you
