JohnnyTightlips
Motorhead
I purchased and installed the ebay knock off GFB dual port from here http://www.ebay.com/itm/New-Mazdasp...ash=item4aefa1cf54:g:WvIAAOSwYHxWISBE&vxp=mtr I offered them 105$ and they took it.
I have been running this valve for 6 months with no issues at slightly higher than stock boost levels "VT OTS map".
I will include some pictures when I get more time. @SharksInSpace also owns this valve and got it for around 85$.
Quality - Looks good, adjuster is hard to turn but smooth. Trumpets are thinner metal but won't crush too easily. Valve looks like GFB looks to be machined well. Spring is heavy duty. Not sure if GFB whistle trumpet fits.
Install - Very straight forward install. I used their gasket as well with no issues. Remove the stock BOV and install this one. I had a longer vacumm line on hand and used that, can't recall if I for sure needed it.
Adjust - Once it was installed and set for about 50/50 vta I started to adjust it. I used that video as a reference.
Happiness - 10/10 sounds great and no issues at idle, even set for 100% vta I just get an occasional backfire but no idle issues.
Mine says xs power on it, @SharksInSpace got one without a decal and it was a little cheaper. It appears to be the same valve. He also took it apart to turn the vacumm port which I did not do and hopefully he can comment on this.
Sounds!!! - RICE RICE BABY! 35% VTA
Pics -
UPDATES!!!
The GFB Whistle Trumpet fits this valve. @SharksInSpace has included a video.
https://www.rallysportdirect.com/pa...-valve-whistling-trumpet-attachment-low-boost
Low boost attachment works well with this as you are not doing 100% vta.
