EWG screamer pipe
  • Thread starter Thread starter Majin
  • Watchers Watchers 2
Majin
I just picked up and installed a XS Power V3 exhaust manifold with 44mm EWG. Does anyone have any pictures of how they ran the screamer pipe?
I don't want a hood exit and that space between the alternator and downpipe is pretty small. I was going to be looking into a custom fab shop to build me a screamer pipe that will run down the side of the downpipe.
ALSO NOTE for future purchasers of this manifold, there is no room behind the manifold and it crushes in the heatsheild, the manifold moved my turbo over slightly and caused the turned down turbo to foul on the coolant line that T's to supply coolant to the turbo and the last gripe I never put much thought into is the EWG placement is not ideal.
I know this is a few months old but I basically removed the heat shield from the O2 sensor, wrapped it and its wires with aluminum tape. Then angles the pipe against the DP towards the driver's side of the car. It fits well and doesnt cause any issues.
