HPFP irratic reading at high RPM
i ordered a new pump. ill put my internals in it. the connector on my spill valve is broken anyways. i just hope the spill valve is the issue. like i stated before. my internals look great.
Seems unlikely. What are you going to do if swapping the HPFP results in the same issue?
Edit: Also were the internals scored or marred in any way?
i didnt see anything that looked scarred up or anything on my internals. ill get a pic of them when my new pump comes in and i replace that. any other ideas? another 400 bucks in internals would suck being mine are only a little over a year old.
Here's my internals. The only thing I see is the dark band in the middle of the shaft. I can't feel it but I can see it.
If you put the piston in the collar dry, does it move easily or is it rough and hitchy? They must be perfectly clean when testing (use lighter fluid for this).
