I did a lot of reading yesterday about SWAS and the various ways people have been defeating it, and it all ends with dash lights on and potential abs/dsc defeat. I want neither of those. SO I dug into it a little more and got the sensor voltage defaults (ie; the voltage that tells the system where the wheel is pointed). Centered puts out .25 to .75 volts, and anything left or right does .75 to 4.75 volts. The very first thing I thought was "well f**k, why not just use a simple integrated voltage regulator to cap the output voltage at .75 volts?". Yes, it`ll work. It`ll work like a champ and completely solve all of the headaches associated with SWAS.
"So, Jef, what`s the catch? If there wasn`t one you`d have surely put that into action."
There is a catch, but only a little one. I can`t find anything lower than a 1.5 volt regulator. Given how sensitive the system is I don`t think it`d do any good allowing more than the .75 volts through. So I need one of two things to move forward: either a .75 volt regulator source OR evidence that the neutering is triggered at a higher voltage (the system giving allowance for X degrees off center). Again, referencing back to how sensitive the system is I`m betting that there is no wiggle room, but we can hope.
With that no on the table, what say you? Can we source the correct regulator?
