Mazdaspeed 3 clunk from front end
  • Thread starter Thread starter MPS
  • Watchers Watchers 2
MPS
Hello frends, i return from road trip yesterday and some strange clunk sound from front end started to driving me crazy, it can be heard when go slow, even 5kmh and slam on the brake, but only once, then you must go reverse, and accelerate, then hit again brake to hear it again, also when go left and right, suddenly changing directions, it make clunk noise from driverside foot rest or middle of car, can't really decide, all ball joints, tie rods, end link's etc, everything that is front suspension related is changed, suspension bridge is checked, no play, new front shocks and thrust bearings, wheel bearing are okay, everything seems to be spot on, but there is that clunk sound, also it can be heard when is left front wheel on side walk and i turn steering wheel left right while car isn't moving.. Any idea what to check else?
Engine mounts are good, steering rack also..
Only thing that crosses my mind is inner cv joint that have little play, what you think?
Sway bar end links
Nope, i think i find the problem.. 3 bolts that hold thrust bearing or shock, whatever, 2 of them was slightly lose, i tighten them up, i tried on parking lot and there's no more clunk sound, will test it tomorrow to confirm
