MDB's Ultimate Money Pit
Mr Dangly Bitz
Well here we go.
So, back in 2016 I had to get rid of my MS3. Always wanted a rotary and never really saw the opportunity financially to pull the trigger until then. Fortunately the wife is just as nuts as I am and pushed me to get one regardless of how bad a finacial decision it would be. So, I picked this 1993 FD up back before pricing shot through the roof.
Was in decent shape, paint was faded, typical 5th gear synchro failure. BUT it had a freshly rebuilt keg with Goopy apex seals, so that was a plus. Below are some shots from the listing. Picked this up on facebook marketplace. 99k on the chassis
Since ive had it, a lot of time has been spent going through the car ensuring everything is working properly and addressing everything around the engine before going for power.
To date:
Engine:
- Rats Nest Refreshed
- Haltech Elite 2500 ECU & associated hardware
- Catless Downpipe
- Tanebe Catback w/ restrictor
- Koyo dual pass radiator
Drivetrain:
- Rebuilt rear diff
- IRP Engine mounts
- Brand new OEM 5 speed with shorter JDM 5th so its actually useful with ACT 6 Puck
Suspension:
- Ohlins Coilovers
- Superpro bushing kit
- J-Auto FD Pillowball bushing kit
Exterior / Aesthetics:
- RX-Lights LED projector retrofits
- 20% Tint
- Complete glass out respray OEM Mazda Vintage Red
This is how she currently sits at the local C&C making 350whp / 300wtq with maxed OEM turbos and fuel setup
https://www.tiktok.com/@irperformance/video/7311156431313505582
Next few steps are more creature comforts than anything
- Attack squeaks/rattles and sound deadening
- Fix / Replace the stereo
- Install JP3 RX-8 A/C conversion
- Some sort of brake upgrade that will fit within 17" wheels (if not, a rebuild of the OEM setup)
Ultimate power plans (require selling of 1 kidney and 40% of liver) ~400 - 450whp
- EFR 8474 turbo kit
- V-mount IC setup
- 850cc primary / 1680cc secondary fuel injectors w/ rails, regulator, pump etc.
Beautiful!
Nice job bringing her back to life!
I'm not familiar enough with these as far as modding, but what does it take to make those power numbers?
B
Beautiful!
Biggest restriction in the system is the fueling windows. Stock turbos are good for ~12psi before becoming flamethrowers
The fueling im looking into should be good for 500-550, but the stock ports will become a choke point at 450 or so
Anything at or near 500 will require doweling and reinforcement of the keg itself to prevent flexing and coolant jacket failure. The seals in the motor should be good enough to handle it.
B
Damn, I suppose it's time to sell the kidney and 40% of your liver.
I never would have thought it would take so much to make power on the rotary.
Its not much more than any other car, all the components were just sized correctly for factory levels without much headroom. It also depends on goals, im looking for maximum spool for street use
There is the rotary tax on components though, i thought the speed was expensive.
Turbo kit I am considering https://turbosource.com/products/turblown-engineering-13b-rotary-cast-efr-iwg-turbo-system
V-mount IC setup - https://www.nengun.com/greddy/v-mount-layout-kit-v-ii
Fuel system should run another 1500 or so once all said and done.
EDIT: I should add, there is a signfiicant price difference between making power, and making power reliably. That is where the "rotaries need a rebuild every 20 feet" mantra comes from. Doing it once and doing it right requires cash
The tax is outrageous for sure.
That's a nice turbo kit and IC kit. That would be really nice. The prices are definitely through the roof. However, with any car, you get what you pay for. But 6k+ for a turbo and intercooler is... A little wild.
Do it right do it once for sure! I wish more people understood that concept. Same goes for preventative maintenance.
Slow tedious project. Car is beautiful either way man.
I am completely green with envy here! That is my #2 want car, immediately behind a classic 911 (equally spendy)
You have same taste too. spoiler less, the round fogs, rims. I like it all...Ive always wanted Innocent Blue tho ;)
Keep us informed...Ill be watching!
350/325 @6k
had to retune due to my cat deciding to brick itself and clog the exhaust. New tuner. He didn’t like the injectors running at 110% like the previous tune, especially on 30 yr old factory components.
limited me to 85% IDC and basically run out of fuel at 6k so that’s the new temporary rev limiter
full fuel system upgrade is next. Thinking 1000cc primary’s and 2500cc secondaries with a dual in tank fuel pump setup and flex fuel sensor. Considering radium for the components.
So, not much to report on the car as of late
Fixed the overheating issue - stock Tstat was getting stuck - replaced it with a 165* fast acting, replaced the hoses while i was in there
Eliminated the smog air pump and associated components in preparation for an upgraded fueling system
Found out the wiring harness is shot, so that will have to be replaced with a custom one eventually
Broken clamp on one of the small coolant lines was giving me a minor leak / smell which was buried under the intake manifold
Getting a paint correction and ceramic coating next week
And i thought the MS3 engine bay was ugly......
So finally pulling the trigger. Decided to do everything at once since it makes the most sense over this winter
Turblown EFR 8374 IWG turbo kit
IDX 1750 injectors x4
Radium Rails, Regulator, Fuel Dampener
Walbro 535LPH fuel pump
Sakebomb IGN-1A ignition kit
Pettit Racing Intercooler Kit (SMIC)
JP3 Battery Relocation Kit
LMS EFI Custom Haltech Engine harness - additional provisions for e85 flex fuel sensing and EGT sensors
Will begin the teardown in october/nov when it gets put up for winter. Will enjoy it as is for the rest of the season
Now the hunt for a tuner begins....
Teardown has begun
Pulled the intakes, intercooler, battery, upper intake manifold and associated charge pipes
Will begin pulling the rats nest out and the factory ignition system.
New fuel setup should be here in about 2 weeks along with the battery relocation kit
Turbo kit is still 2 months out.
Shop dog is pissed I’m not playing frisbee
worked on the engine side fuel system today. Pulled the entire factory assembly out and replaced with radium components and a JP3 kit. 1050 primary and 2600 secondary. Total flow capacity is around 7k cc. Good enough for e85 if I ever go that route.
Came with all the fittings and lines needed to replace the entire setup. Just doesn’t have a fuel pressure gauge. So that’s on order.
When pulling the old injectors the basket diffuser on the rear primary broke. Shitty plastic. Fell down the intake runner. Fortunately was able to suck it out from the intake side and prevent it from falling into the motor itself.
Assembly was straight forward. Pressurized the system and no leaks. Happy with how it turned out. Will tackle the tank pump when I do the battery relocation.
I’ll paint the throttle body and upper intake wrinkle black while I wait for the rest of the crap to arrive.
Also ordered a pnp ign-1a ignition upgrade.
