Will said that if I bought it, it would be at my own risk, not returnable. I went ahead and ordered it figuring we could get it to work. What you said about them not having a test 6 didn’t make sense to me as I know they still make parts for the 6. I went looking on FB to find what you said. I did not find that. And in fact, I found a quote from CorkSport specifically saying it has been tested and will not fit. This was in the FB comments on their announcement of the product. Someone asked if it would fit the MS6. This was the response from CS:
“It will not. The speed 6 harness routing and coolant hose dont cooperate. “
So, CS specifically says they have tested it and it doesn’t work. But, that said, I don’t recall there being coolant hose in that area. I can’t go run look at the moment as the car is in the shop. From memory, I know there is the small coolant lines for the throttle body and the top radiator hose if they mean either of those. But I don’t have coolant going to my throttle body and I’m pretty sure the top radiator hose is out of the way. Now, I did modify the wiring harness a bit to make a bit more room to fit the 3.5” intake. So, I’m thinking that much can be handled. Probably. After all, other 4” intakes work.
I already turned in my order before finding that FB post. So, I will see if I can get it to work.
