Mtnbker3531
Well its another "I'm using a lot of oil" thread. I recently installed a BNR S2 to replace my tired K04. I have since realized my leak down numbers where not good. Due to inexperience I assumed if I was in the green on a Snap On tester I was good. Well I'm wrong that's for sure. So I'm assuming I have an oil control ring or a ring land issue at this point.
Compression is 185-190 across all cylinders car runs great and makes good power. I don't have any codes and my tuner says all my data logs look good. Currently on revision one from my base tune and I've seen 18.5 peak. Car feels better than it has in years. The issue is I'm using a quart of oil in 500 miles or so.
No smoke on start up or idle and its hard to tell if I'm making any out the exhaust while driving. I think on full boost high RPM I'm seeing some but its nothing compared to the smoke show I was making on boost with the K04.
So at this point further tuning is on hold until I resolve the motor issues. I've talked to a local shop that can help me out. I plan to pull the motor and drop it off to them so they can tear into in and fix my issues. I'm not looking to make big power so if I can refresh this motor on stock internals and be on my way I'll be happy.
