UncleTurbo
I am having a bit of a weird issue with my car and throwing code P0193
A couple weeks ago the car just started stuttering regardless of how fast or slow I was going and the code P0193 showed up on the scanner. I ended up getting Fuel Rail Pressure Sensor 0261545074 online to see if it would fix the issue but it actually made it worst and the car stopped turning on. (the only mod the car has in a K&N short ram intake with a little wall.)
I took it to a local mechanic where he put back the original fuel pressor sensor and "cleaned" the intake filter and suddenly the car started running again BUT the mechanic did not hit boost enough to see if it had any further issues. As I took it for a spin and hit WOT the car starts to buck/stutter... I took off the intake filter and suddenly the car was working like it was suppose to without the stutter....I ran it for 3-4 pulls, went home and put the filter on as I didn't want to damage anything further.
I drove the car for a week without going over 60% throttle and it ran ok. Once the COLD weather hit it just started bucking/stuttering just driving lightly down the road again. Once it warmed up the car stopped but then I got the code P0193 again along with a P2177 System too lean off idle Bank 1. I am having trouble finding an legitimate Fuel Pressure Sensor to replace the OEM one. Does anyone know what could be going on?
Today I cleaned the contacts of the ground cable like another user told me to do but it still bucks/stutters... At full boost the car shortly stutters/bucks and all of sudden just launches at full force... I have no idea what's going on.
