sickms3
		Two years in the making. I'm installing the new engine this weekend.
Go Fast Stuff
Engine assembled myself
Bored 0.020" Over
PTE 5858
Bosch 3.5-Bar Map Sensor
Bitwise Motorsports Bosch MAP Sensor Connector
OEM Head Bolts
OEM Main Studs
Manley H-Beam Rods
CP Pistons
OEM PCV Plate
Treadstone TR8 Intercooler Core
HTP Under Routed FMIC Piping
HTP 4" Intake
OEM Injectors (Serviced and inspected by InjectorRX)
CP-e Turbo Manifold - Hot Coated
Corksport Injector Seals
Kozmic Motorsports OCC
Kozmic Motorsports Downpipe
Kozmic Motorsports Oil Feed Line
Kozmic Motorsports Oil Return Line
Kozmic Motorsports Dump Tube
Kozmic Motorsports Primary EGR Delete
Kozmic Motorsports Secondary EGR Delete
Tial MV-R 44mm Wastegate
JMF Intake Manifold
Southbend Stage 3 Endurance Clutch & Flywheel
JBR 3-Port EBCS
HKS 3" Exhaust
Aquamist HSF-4 Meth Kit
JBR Oil Pan Baffle & BSD
Rolling and Stopping Stuff
Enkei RPF-1 17x9 +45mm
Sure 10mm Spacers - Front
DBA 4000 Series T3 Rotors - Front
Hawk HP+ Pads - Front
Centric OEM Blank Rotors - Rear
Hawk HPS Pads - Rear
Techna-Fit SS Brake Lines
Motul RBF-600
Suspension
ISC Coilovers
COBB Front and Rear Swaybars
JBR RSB Bushings
SPC Camber Arms
Interior
Eonon GA5151 Android Head Unit
Perm Butt Plug Shift Knob
Autopower Race Roll Bar
CP-e 3 Gauge Dash Pod
Aquamist Meth Controller
AEM Failsafe
AEM Oil Pressure
			Go Fast Stuff
Bored 0.020" Over
PTE 5858
OEM Head Bolts
OEM Main Studs
Manley H-Beam Rods
CP Pistons
OEM PCV Plate
HTP 4" Intake
JMF Intake Manifold
JBR 3-Port EBCS
HKS 3" Exhaust
Motul RBF-600
Suspension
ISC Coilovers
JBR RSB Bushings
SPC Camber Arms
Interior
AEM Failsafe
AEM Oil Pressure
