Sickms3's BT Build
  • Thread starter Thread starter sickms3
  • Watchers Watchers 11
sickms3
Two years in the making. I'm installing the new engine this weekend.
Go Fast Stuff
Engine assembled myself
Bored 0.020" Over
PTE 5858
Bosch 3.5-Bar Map Sensor
Bitwise Motorsports Bosch MAP Sensor Connector
OEM Head Bolts
OEM Main Studs
Manley H-Beam Rods
CP Pistons
OEM PCV Plate
Treadstone TR8 Intercooler Core
HTP Under Routed FMIC Piping
HTP 4" Intake
OEM Injectors (Serviced and inspected by InjectorRX)
CP-e Turbo Manifold - Hot Coated
Corksport Injector Seals
Kozmic Motorsports OCC
Kozmic Motorsports Downpipe
Kozmic Motorsports Oil Feed Line
Kozmic Motorsports Oil Return Line
Kozmic Motorsports Dump Tube
Kozmic Motorsports Primary EGR Delete
Kozmic Motorsports Secondary EGR Delete
Tial MV-R 44mm Wastegate
JMF Intake Manifold
Southbend Stage 3 Endurance Clutch & Flywheel
JBR 3-Port EBCS
HKS 3" Exhaust
Aquamist HSF-4 Meth Kit
JBR Oil Pan Baffle & BSD
Rolling and Stopping Stuff
Enkei RPF-1 17x9 +45mm
Sure 10mm Spacers - Front
DBA 4000 Series T3 Rotors - Front
Hawk HP+ Pads - Front
Centric OEM Blank Rotors - Rear
Hawk HPS Pads - Rear
Techna-Fit SS Brake Lines
Motul RBF-600
Suspension
ISC Coilovers
COBB Front and Rear Swaybars
JBR RSB Bushings
SPC Camber Arms
Interior
Eonon GA5151 Android Head Unit
Perm Butt Plug Shift Knob
Autopower Race Roll Bar
CP-e 3 Gauge Dash Pod
Aquamist Meth Controller
AEM Failsafe
AEM Oil Pressure
Good to see you on here, man. Excited to see how it turns out after tuning and to watch your tail lights fade away! :D
Any status updates, Jason? Excited especially to see the tuning begin!
Engine is ready to be pulled. Been dealing with the axle not coming out, but looks like I might be able to get the engine out with it still in the trans.
Pulled the engine out Saturday. Huge thanks to @Dub-S2K and Sumo for their help. David could probably do this in his sleep. lol
Also got some parts in the mail.
New driver's side axle
HTP Battery tray, JBR Recirc hose in white, and OEM slave cylinder.
New intake filter
And dropped off several things to get powder coated, including my valve cover after having a bung welded to vent it.
[doublepost=1459140618][/doublepost]The axle came out with the trans. Once we put the engine on the ground, we were able to pop the axle out by prying above it as opposed to below it when everything was still in the car.
I'm taking the axle back to where I had it replaced in 2014 to see what they'll do for me. It's separated at the u-joint but I never had a problem with it until we tugged on it.
Going to clean up the engine bay and finish assembling the engine this week and hopefully have it ready to go in and started by the weekend.
lmao...i haven't done anything this week but i'll probably put a few hours in on the new engine after work.
i need to torque the mains. i didn't measure rod stretch, but according to the sheet, 100ft-lbs is right in the middle. torquing with 30w oil.
then i need to pull the oil pump off my old engine and use those bolts to put the new oil pump on the new engine.
after that, i can throw the head on and get the thing ready to be dropped in saturday.
How close are you? Thanks for the shout out and I'd be happy to help some more since I am free this weekend. Mine is pulling like a beast...might be experiencing some clutch slippage though...must mean that hp and torque number is increasing. (:
Ran into a problem putting the head on Wednesday. I think when the machine shop removed the dowel pins, they became out of round preventing the head from sliding on.
David at Kozmic is sending me 2 new ones that should arrive today.
Sent from my SAMSUNG-SM-N920A using Tapatalk
o.0 With such an experienced machine shop, such things ought not happen, right? I really don't know, but that scares me a little.
I don't know how it could be prevented. Thin metal that's pressed into a hole. David said that they replace them every time on rebuilds.
Ah, good to know. I was thinking solid pegs, not pegs that're like rings.
Got the pins in Saturday and the head slid right on.
Torqued the head with OEM bolts and ARP Ultra Torque Lube.
Added all this crap
Top tip, use the square part of a zip tie to lock the tensioner in place.
Timing chain cover on and torqued that damn crank pulley bolt.
Installed the oil pan baffle and oil pan and called it a day.
