I've gone with a Luk & Fidanza flywheel combo simply due to me being on a budget when I did the job. Glad that was the case since I had a lot more maintenance to do on the car soon after. Still replace always replace the flywheel bolts since you are already in there to begin with. Also make sure to check your master & slave clutch cylinders just to be sure they're still in good condition. I know that my master clutch cylinder was beginning to show signs of a small leak when I did my clutch so I swapped it out while doing the entire job. Makes it easy when only having to bleed a single time & not multiple times.
