StealthWyvern's MSP
StealthWyvern
Figured I'd post here to add some protege content, not that anyone really cares about the protege anymore. So I've had this car for what seams like forever. @Raider can confirm. I think I purchased this car on 7/11/2008 with about 36k miles on it and now has over 150k road hard and put up wet miles on it
I can't really provide much of the build progress over the years but I can state what I have so far in no real order. I'll have to upload pictures later when I get time.
Mazda 6 17's wheels 17x7 60offset
20mm spacers
ksport coilovers
Energy Suspension 9.8171R pivot style end links
Good ridge stainless yellow rear brake and clutch lines (front blew), Stoptech SS front brake lines
Drilled and slotted rotors
EBC brake pads
626 intake manifold
Perrin FMIC
Perrin Adjustable Short Shifter
Bronzeoil 3rd shifter link bushings
Kart Boy shifter bushing
weighted shift knob
Fidanza flywheel
Exedy Stage 1 clutch
mfactory LSD
Custom top mount turbo setup using a Kinugawa T2 Turbo Manifold
Rear Sway bar lock collars
3inch turbo back exhaust with a magnaflow muffler
Haltech Elite 15000 with a WB01 wide band and a boomslang PNP harness
Coil On Plug conversion harness using Toyota 1FZZ Coil packs
EGR Delete
66duro AWR motor and trans mounts
custom dual cluster pod
steering Colum pod
prosport boost guage.
Dave B guage rings (I think )
custom molded 12inch Punch P2 sub woofer in trunk powered by a 450watt jensen amp
Alpine headunit.
color matched projector headlights
Turbo manifold test fit
Turbo loosely sitting on top of the manifold
tweaking the oil return line, and "trimming: of the manifold, and turbo exhaust flange.
tight tolerances
IN progress modification of the stock WGA bracket
First time messing with the elcheapo welder
not winning any sema awards with this job, but it will do
DIY AN lines
3inch stainless vband exhaust
3inch magnaflow muffler
one piece hot pipe, this thing is a bitch to get in and out.
coil on plug conversion
LED reverse and cluster lights.
and i think last is the projector headlights.
and one last one right after I just completed detailing it for my sons scout car show.
Awesome stuff! Can you run Audi R8 or LS D585 coils? I was running the same Toyota coils in my Miata but swapped to R8 coils and noticed a big difference. The R8 coils definitely pull power and need a high current driver in the ECU to use them. I still need to wire in a separate 12v relay for them so they aren't pulling off the main relay but so far have been good.
Loved my 99 Protege. Wish I had it today so I could do a KL-ZE swap. For 17 years it was the most dead nuts reliable car I have ever owned!
Nice to see one still alive.
Tha ks everyone. It's far from nice but if definitely not the worst condition one out there
I can't say that I have looked into the r8 coils. are they the same connector as the Toyota one and or same pin layout? I'm sure the haltech can run them, just need to know the proper dwell time etc to set them up
