Yes that was a question. Are you sure it is exactly the same? If so that probably opens up a fuck ton more options for pu owners. Seeing as the St is so popular.
What's the point, are the ST ones cheaper? SP63 and others have offered check-valved/baffled oil filler breather caps for us for a while that're high-quality with great features.
CFM Performance Valve Cover Breather for ST is the same same the Speed on SP63. The CFM pick was something used in the past. I forgot the model number.
Be careful with the valve cover breather if you track your car. I had oil coming out of my cfm breather whilst on the track. Mostly during fast left handers.
SP63 and CFM are the same thing. The "check valve" is just a ping pong ball in the housing with a filter on the top. That filter is gonna get oil in it.
