Finally washed it again. Going in for the body work on the 12th. Shop is confident they will get a good paint match.
Car is back from body shop. I think they did a great job. I think I’m going to leave the silver fog rings and chrome emblem this time. Need to polish my headlights.
3B6470DF-B840-487B-B36B-D6848290101D.jpeg FA9D7528-97A9-4527-9162-8C5874B33B3E.jpeg
Installed front and rear TB Performance tie bars and a GFB Bov/Bpv. The car seems to handle better and possibly have less understeer. Bov sounds great, it’s set about 50/50 and I do get a little pop out of the exhaust on shifts every once in a while.
Moving to Manitoba next week so a block heater was installed. all I have to say is fuck you 1st exhaust stud. Mazda instructions say remove #1&2 on the back left to get access for tools. I've seen guides say just #1 which I'd agree to. Since mine wouldn't come out I did it with them in...2 clicks at a time FML. Anyway it's done.
Edit: while having the under tray off I noticed a weird rub on the oil pan, not sure what from.
What a pain in the ass. Perseverance should be your middle name!
Weird indeed. Was that from someone using your oil pan as a jack point?
Lol yeah it was a PITA. But I had already cracked the seal so no going back...
Umm I'm not sure unless a shop has because I never jacked it there and I'm the only owner. It's been at 2 different dealerships, one auto body, and that's it. most of my lifting is done on a hoist as I've had access to one for 5 years now.
I'm leaning towards perhaps the under tray rubbing in a weird way? This clearly isn't new I cleaned it up for the pic. I cannot recall if it was there when I replaced the OEM tray for a cheap Amazon one when it does.
Day 2: oil change, coolant flush and JB welded that scuff on my oil pan. Can confirm its from the undertray rubbing. Stupid Amazon part as a metal bar in the back for ridgidy and it was bent up so that was rubbing on my oil pan. Smacked that down with a hammer plenty of space now.
Oh and I also rotated my tires, lubed all my door hinges and shifter.
IMG_1578.JPG IMG_1586.jpg I somehow broke the lower coil on my rear right side coil spring the other day, finally got both the rears swapped out for OEM.
On another note selling MS3 2 peace OEM rear springs /s
165k miles
