First and foremost I am tuned for e48. This thread is to open further discussion on the topic. I have been having problems with high ethanol content and fuel level sensors failing. From research I've gathered, it seems gen 2 sensors are more prone to failure. So far I have replaced the original sensor seen in the photos with no luck. The oem replacement sensor failed in less than 2 weeks time. I have yet to pull it out, but have another on the way.
I found other platforms have a similar issue with this type of sensor, but no real fix. My first course of action in attempting to prevent this from happening again will be cleaning this sensor of corrosion and applying an avionics "fuel lube" I discovered called EZ TURN. I'll submerge the sensor in an e50 blend and see what happens. The data sheet shows this stuff as a good candidate to slow down the problem. It's not soluble in fuel or ethanol and has dielectric properties.
Sent from tapioca
Sent from tapioca
