So, it turns out I didn't know how to do a leak down test properly. I was following the instructions for good leak down testers that have an orifice between the two guages, on a cheap leak down tester that does not. Got the following results, and repeated the test a few times to ensure I wasn't feeding myself bad data
Pistons 1, 2, 3 - between 6 and 10 percent leakage
Piston 4 - between 15 and 18 percent leakage
I took my valve cover => TIP tube off and felt the airflow coming from the crank case - definitely more airflow with piston 4 versus any of the other three.
I then sent a bore scope down piston #4, and thankfully did not see any carnage. Some light vertical marks, but I don't think these are cause for concern. Maybe they are, idk, tell me what you think
So I'm now debating on taking the head off the engine and removing at least piston #4 to inspect its rings. My machine shop gapped and installed the rings on the pistons - maybe they gapped this one huge, maybe a ring is on upside down, maybe one is broken, who knows until I take it apart.
Would it be ill advised to disassemble my motor over this? Would 2x the leakage on 1/4 cylinders actually realistically cause high RPM KR readings like this?
