gv_racing
Hey all, long time lurker first time poster. I pride myself in being a pretty good automotive troubleshooter, but this issue has been absolutely kicking my ass on my fresh engine and setup. I need the help of the MPS hive mind.
ENGINE/DRIVEABILITY
Year/Make/Model: 2010 USDM Speed3
Mileage: 210k kms body/trans 1800kms engine
Concern: 3+ KR after approximately 5800RPM
DTC's: Nothing interesting. P0401 P0421 P2006 P2009 (No EGR, no VCTS, catless)
Modifications:
Built engine with stock valvetrain. 88mm Mahle 4032 pistons, Manley H-Tuff rods. Machining done by Arsenault Cylinder Heads in NB Canada, and assembled by yours truly (there's the issue right there)
CST4 IWG
CS EBCS
Damond 3.5 TIP
Damond Focus ST Mani adapter, non PI
Damond BSD
Damond "stage 1" catch can with the VTA check valve + breather
Damond street RMM
Damond EGR delete
Stock side mounts (sus)
Corksport TB
Corksport TB Spacer
AEM methanol kit shooting into the TB spacer (not active in this stage of the tuning)
Treadstone TR8 core and custom piping
ACT ZX5-HDSS clutch kit
Autotech HPFP bits
VS Racing x50 BOV (tial clone) with a 12psi spring
Serviced fuel injectors + new Overspeed seals purchased from Chris Ward Turbochargers with only 1600kms on them at this point (I pray that these are not the problem, I did everything right boys )
ECU/Tuning Software: Stock/ Accessport v3
Tuner: Will Dawson @ PD
Is the concern intermittent? Nope
Can you duplicate the concern? Yes, every time
Recent Repairs/Troubleshooting Steps:
- Secured the knock sensor wire REALLY well (the sensor is torqued to 15 ft lbs)
- Tried another set of brand new NGK 6510 plugs gapped by me to 24 thou
- Tried two different sets of OEM coil packs off of my parts cars
- Tried tweaking/ re springing the terminals inside the injector connectors to ensure a good connection
- Checked the visual cleanliness/ resistance readings of the five engine bay ground locations I know of
- Checked the resistance between the connector and each injector connector terminal searching for internal breakages
- Cleaned mystery dark fluid out of the inside of injector connector #4 (wtf? it is positively not wicking up the harness, is it leaking out of the injector? I will be monitoring this as I continue to drive the car)
- Did the same for the coil pack connectors
- Completely drained the tank and filled up with 91 from a different gas station
- Did a hot compression test, 186/186/192/190
- Boost leak test, putting 20psi in the system takes 65 seconds to reach 10psi, I think that's a good result?
- Cleaned my OEM maf sensor with maf cleaner
- Got pissed off about it, somehow no improvement
I am on my first revision from Will trying to run 21psi on 91 octane. The car pulls nice and hard until ~5800rpm and even after that, you wouldn't always know there was an issue until you look at the KR. Sometimes the pulled timing is felt, sometimes not as much. At this point I do not know if it is genuine predetonation or the sensor picking up noise. I do not have access to E85 to see if it goes away. I am including four data logs. 12 is when the issue was first discovered, 22 and 23 are after I tried new coils and plugs, and 36 is after attempting everything mentioned above just the other day. 36 appears to be a mild improvement but it may have been a fluke or related to hot weather, but still not where I'd like to see the readings.
Also worth mentioning is that I am running a f#@ked up stock PMM that has lost all its fluid. I just lubed up and ordered the Damond side mount combo set as I already have their RMM. Could be the source of the readings, but I doubt it. We will see.
Thanks gang
ENGINE/DRIVEABILITY
Modifications:
CST4 IWG
CS EBCS
Damond 3.5 TIP
Damond BSD
Damond street RMM
Damond EGR delete
Corksport TB
Corksport TB Spacer
Autotech HPFP bits
Thanks gang
